I'm going to be doing another 1/12 scale panzer tank and I'm planning on using two sets of gear boxes to drive it.I could use the typical single set of HL gear boxes and belt drive system and gain more power by gearing it down,but then I would loose to much speed.So I would like to try two sets of gear boxes,one set in the back and one set in the front.Instead of a front idler there would be another sprocket and drive motor.These tanks are a lot heavyer than a typical 1/16 tank,and I know they are putting a heavy load on the HL system I used.With 2 sets of HL gearboxes, boards and batterys there would be lots of power without sacraficing speed.My question being,does anyone know if I can run two of the main boards with just one of the little boards.Thought it might work by using a Y-harness from the little board to each of the big boards. Can anyone offer any help or suggestions here.???
Thanks, BIGMIG
