RCU Forums - View Single Post - Why does it screech like that?
Old 10-06-2007 | 09:48 AM
da Rock
Default RE: Why does it screech like that?
Gearing often can be screwed up by taxiing a spinning prop into high grass. The grass tries to stop the prop while the motor tries to speed it back up. The two different forces often push the gear adjustment out until the gears start to slip. And the slipping stops the pushing and you wind up with poor gear mesh.
