RE: Brent Good Custom Airframes 50cc Yak 54
Scott
You are correct. Those parts get you the sheeted wings, stab and rudder as well as all the laser cut parts for the fuse, a canpy and cowl. With the kit you will also be getting the rest of the sheeting and balsa for the hinge lines.
You will need to cut out the ail, elevators and rudder form the sheeted foam parts. I will be showing how to do that later in the build thread. We usually cut out the surfaces with a band saw. It can also be done very easly with a razor knife. I will also be showing my method for drilling the hinge line before you bevel the surfaces. This insures that the hinges line up perfectly and are exactly on center. This is a very easy kit to build and I am always availabel to answer questions.
I hope that you get one for this winter building season. It is fun to build and a total kick in the a@@ to fly!
Brent
