RCU Forums - View Single Post - How well did your YS run after sending it in for service?
Old 10-08-2007, 05:34 PM
skidd1000
Default RE: How well did your YS run after sending it in for service?
Hey Troy. Thanks for the info. I do fly at a sod farm, sometimes on grass and also on the fresh cut dirt. I do not have any air cleaner on the carb so I would bet that you are right about scored liner on piston. The power has been getting progressivly worse. Is this a job better left for ys service?Ps I did take apart the regulator and did not find anything that looks out of the norm. Im sure that I can find someone at the field with a compression testor, what kind of reading should I get with the ys 63s?
