RCU Forums - View Single Post - How to make a leading edge???
Old 10-12-2007 | 10:15 AM
SST
Default RE: How to make a leading edge???
Unless the LE is for a flat plate wing, it will be the wrong shape with the same size pipe method. Most leading edge high points are somewhat below center, and the upper side is at a different angle. For a symetrical LE, you'll want to use a pipe with a larger I.D. than your LE, so there is still an angular match to the wing ribs.
