RCU Forums - View Single Post - How to make a leading edge???
Old 10-12-2007 | 11:43 AM
dr_wogz
Default RE: How to make a leading edge???
Ditto. Just glue the stock on, then plane & sand to shape. use the longest sanding bar you have.
The inside pipe idea is good, but I wodul go with a large ID, and use 1/3 of it as your sanding bar, as opposed to 1/2. YOu'll get more use out of it, adn won't be 'pinned' to a certain size.
Also, you can make card templates (cut out) for teh LE profile. Make a few, one for the root, one for the tip, and one, two, three for teh center sections. Then just sand to match teh template
use teh
