RE: Idle Up
it brings your speed to a constant so you can then use the positive/negative pitch of the rotor blades to control movement..
DISCONNECT THE MOTOR!!!
then turn everything on and plug it in.. look what happens to your swash when you click that button to idle up, I believe it moves up the shaft to allow the +/- of the rotor blades.
