RCU Forums - View Single Post - Single or Double Converstion???
Old 10-13-2007 | 08:15 AM
da Rock
Default RE: Single or Double Converstion???
Here is a perfect example of why the term "conversion" means so little and can actually confuse our decision when shopping for RXs.
Do you see the term used anywhere in the description of this RX?
But read what it says about the receiver's range.
This is the Berg Microstamp 4L 4 Channel FM Micro Receiver from
Castle Creations.
FEATURES: Small and lightweight design yet still yields solid performance in
harsh indoor RF environments, ParkFlying, or even at the flying
field in your nitro powered models.
Delivers full range so it is perfect for any 4-channel operation from
small indoor electric models to full-blown glow powered models
Auto detecting Positive or Negative Shift polarity
Fail safe (programable ON and OFF) upon 2 seconds of no signal,servos
move and hold to pre-programmed positions until signal returns
Hold Mode (programable ON and OFF) all servos are held in positions
of last known good signal before signal loss until signal returns
INCLUDES: One Microstamp 4 channel receiver
Two jumpers (used to program Fail Safe, Hold Mode & other operations)
One Castle Creations logo decal
REQUIRES: Castle Creations Berg Micro Crystals (CSEL01**)
SPECS: Length: 1.35" (34mm)
Width: .60" (16mm)
Height: .35" (9mm)
Weight: .14oz (4 grams) with wires
Antenna wire length: 38" (965mm)
Filtering: Triple tuned RF circuitry. Steep Flank 8-pole IF ceramic
filter. True DSP Filtering in the microprocessor decoder with
adaptive algorithms based on signal/noise ratio of the received
signal
Sensitivity: about 2.0uV
