Got the rest of the tail formers installed. Placed masking tape about every 1-1/2" to get everything tight in place. Used a pin across the bottom of the tail as that joint wandered one way or another. the top of the sides has the fuselage bottom to hold it. I put the pin through after taping the tail together and then used it like a lever to get the tail lined up and then taped in place.
Going to install my servos inverted to get them on the right line of where the regular tubes would run. Will use 2-56 rods for the control connections I think. Installed the mounting blocks.
Building with Titebond II takes a while longer but fall weather is here in the NW and I have other birds to fly on the good days so no worries.
somegeek
