RE: blade cp+ question and problem.
Hey Chris, One of the older gents from the thread WEEEE.....CP went through the glitch thing awhile back, and could never figure out for quite awhile what it was, and tried everything...New crystals, even .....Nothing....Guess what it was ? There was a Prison 4-5 miles away that would glitch his bird...Nightime was fine, daytime....Better stock up on parts ! The cure...He got a DX-6...And the problem was solved. Try swithing out your crystals and see if that might help also. That is exactly why in a few days I'am switching over to a DX-7...I don't want to have to worry about any interference..
The 72 mhz on the cpp is in cb radio range, and some trucker 15 miles away on the freeway with an illegally amped up cb radio broadcasting a bazillion watts is just waiting for you ----
Also, the stock TX's have been known to go out, and if flying in a tight area like your garage, try reducing the antennae length just a little...This has helped a few guys also... Good Luck, Jeff
