Hello wackywheelz and thanks,
Just briefly looked over your instalation procedure,looks very complete.I have done several instalations now,but I will also look over your procedure in more detail.Don't hurt to double check yourself,can save a potential problem.Looks like your layout should be placed in the tank-FAQs section for others to use.Thanks again--
What I hope to gain is more power for the heavyer tank,and less of a electrical load on the boards by using two.(one for each set of gear boxes)And two batterys in parellel for a stronger power supply. Thanks again---BIGMIG
Additional note,had talked this over on another post with darkith and he seemed to think this will probly work.Although he suggested i try it on the bench before actual instalation.That was a sound idea,but I went ahead with-out a bench test.Hope I don't regrete that decission. BIGMIG [:-][:-][:-]
Fogot the pictures----
