Instaled the elevation control tonight so thought i would add a few pictures.Cut out a piece of sheet plastic a little larger than the exsisting hole up into the turret.Super glued it in place,and removed the gun.I cut off about 1/4 inch from the bottom of the tab on the gun that will ride on the cam on the elevation control.Did this so I still get nice elevation control after fitting the control under the gun.
Drilled two holes for wires to pass through to the lower hull,all the turret wiring will go through these two holes.Pretty basic but there it is,pictures to follow--BIGMIG
