RE: 2 for one - Carden 40% Extra 300 Build
I finally had time to do some wing prep.
First I made a template for the servo layout. I like working with
templates to reduce the chance of error.
I needed to cut the servo wire holes so I broke out my Weller
soldering gun and made cutter out of 14 ga. copper wire. I had
seen pictures of this done and just copied it.
Laid out the servo wire channel (straight line) checked the plan
to make sure servo wire would exit in a good spot and burned
the holes. I used an aluminum angle as a straight edge and
a depth guide.
Next I routed out the servo locations, glued in the servo mounts
and put everything up to dry.
