RE: trinity adam drake .28 vs lrp .28 spec3 truggy
also for $250.00 i'd be cnsidering the purpose of this motor...are ya racing or bashing......... if your racing both the Spec 3 and the "Drake" are pretty useless...way too much bottom end and not nearly enough top end, as well both motors have terrible run times for race duty.............. If your racing a good .21 will lay the smackdown pretty hard on both these mills.... not only will a .21 outrun the 28's on the straights but it will also get much better mileage............... the only place the 28's will pull thee 21 is in the low end, but unfortunately on a track with track tires you will never get enough traction to actualy use a 28's low end.......the only 28's worth putting in a truggy are a Ninja 28< radical 28, or a OS 28..... if not these 3 your better to run a good 21............. a Picco P7 EVO2 .21 or example is a $230.00 motor and it lay a serious hurting on a Spec 3, down the back staraight a Spec 3 will look like its in reverse next to a EVO 2......If you want to pull wheelies a Spec 3 and a Drake will do well, but if you want to go fast look to a race motor like a EVO 2
