RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
BTW I am receiving my B-25 on 10/24 tomorow morning!!! Cannot wait to see it! I will work on it to exaustion every day until it is perfect. I will keep you posted on my experience. Tim, if you read this, is the B.25 tail heavy with the OS70's. By design it looks Tail heravy and rerading the instructions it is suggested to install the battery in the noze section below the noze gunner section. I presume that the aircraft is tail heavy. Also for my model I have the MCD472TE glow driver to assist the glow plugs when idling...and maby avoid an engine failure if the low setting is too rich on the carb. I will build and fly this aircraft slightly noze heavy at first...will keep you informed
