RE: fuel?
No trick; the clunk inside the tank keeps the fuel line in fuel, and muffler pressure (or carb pump on a gas engine) keeps positive fuel pressure. The engine itself doesn't care which way it's pointed, it will run as long as fuel can get to the carb.
Just saw your return post. Sounds like you might have a mixture issue. What engine, and have you played with the needles yet?
