RCU Forums - View Single Post - Changing tune
Old 10-25-2007 | 11:55 AM
Charlie P.'s Avatar
Charlie P.
Default RE: Changing tune
ORIGINAL: da Rock
Good thing about retuning is it takes about 15seconds. So why not?
I used to fly a lot of practice flights. Usually 5 flights an evening, at least 3 days a week. Competition will make you do things like that. And I got to know my engine well. And got a feel for the weather. When you get used to your model, if you pay attention to how the engine takes the needle setting, you will too. And most times can feel if the needle needs a click richer or leaner and how much. If you can't fly that much, or fly more than a couple of engines, adjusting the first flight of each session takes almost no time at all. So why not?
Yep. If you're not messing with the low idle setting the main needle is no pain to tune. I back mine off a quarter-turn to start on any given day and then set it for max RPM after a few seconds, then back off a little towards rich. Starting rich has the same effect as starting a gas engine with the choke closed. And, with an engine lubricated by the fuel, a rich start gives a longer lifetime to the engine. 'Course, mine all seem to die of other causes than a natural death of wearing out.
