ORIGINAL: matador_24
Ok, I am gonna try next time. It just wags when I give some throttle, it wags maybe 3secs (not very strong though) before being centered again, it's not too bad. I read about decreasing the GAIN in the Tx, I have a DX7, I set it at 72% which is recommended for the GY401 in all the DX7. The thing is that it was working perfect, that is why I didn't want to touch the gain but I'll give it a try. If I do decrease... how much would be good???? Thanks.
I have the same set-up using JR XP9303. I have 65% gain on both ends works perfectly tail is rock solid. Also if you still have the tail wags make sure you don't have any binding on your links. Hope this helps.
