Tiger 2 Taildragger Conversion
Hey Redtail -
I converted my Tiger2 to a tail-dragger. I moved the main LG blocks forward of the wing spar. If you don't, you'll have to lean the gear waaaay forward to get the axles under the wing LE where they belong. If you don't get the axles that far forward, you may have a problem with the airplane tipping forward, especially if you're on a grass landing strip. I had that experience with another plane until I got the axles under the wing LE.
Good luck with it.
GoMike
