RE: X9303 NEED AILERON SETUP HELP
Once you select Flaperon as the wing type you are finished - there is no need to assign a dual channel for ailerons as it has already been done by the system. Just plug the right aileron into the aileron channel and plug the left aileron into into the Flap channel. Adjust sub trims and travel as necessary for the RAIL & LAIL channels (the Aileron and Flap channels are also renamed by the system when Flaperon wing type is selected). Good Luck.
Len Alessi
Team JR
