Hi willy really sorry got back to you late the leaves are killing a lot of quality time you know !!!!! suck the leaves up look behind you and they back like you never did them[
][&o]
Well anyway started engine da-50 2 gallons ran threw so far so good canopy didn"t vibrate back with clip set up!! enclosed is pic:'s of clips one clip is a cut off relay micro swicth arm long .The other clip is a cut down tie wrap with actualy slides under relay clip forcing it thight ! the red modified swith cap is trimmed to fit in rails and slide. a little unscale but keeps canopy thight!! YOU HAVE TO BEND A LPTTLE ARC TO CRATE SPING TENSION IN RELAY ARM. OK WILLY WILL TALK TO YOU OK BYE!!!!
