RE: TF Elder 40
Nickj,
Please post your progress on the rigging, with a picture or two if possible. I am still concerned about adding weight in the rear. I probably will do everything (covering, rigging, etc.) except painting and rigging the aft fuselage. That way, I can be a little more certain of the weight and balance situation before I proceed. At the moment, I am leaning toward small diameter plastic tubing glued in the corners as a lighter weight alternative to the brass. I have to tell you; it is tough sitting on the fence like I am. Sooner or later I'll have to take the step.
