RCU Forums - View Single Post - Using two batteries at the same time - Update - Its bad!
Old 11-01-2007 | 07:08 PM
Shadow99
Default RE: Using two batteries at the same time
Looks Good Kenny! Your motor will be much, much happier now!
Did you remember to add more HS compound, to the Heat-Sink before snapping it back on? Without it, the motor could still get hot spots, cause the HS doesn't fit perfectly against the motor-can, so the compound fill in the gaps so the heat can be pulled away.
Rick
