RCU Forums - View Single Post - Diode BACK in the 9C??
Old 03-30-2003 | 04:32 PM
JimTrainor
Default Diode BACK in the 9C??
I have a Hanger 9 voltmeter, that applies a 400 mA load @ 9.6 volts. This one:
http://horizon.hobbyshopnow.com/prod...sp?prod=HAN111
It measures 9.4 volts - that is loaded (~400 mA). So there is current flowing. However, the 9c tells me 9.9 volts.
So, I will step out on a limb here and assume the poly-switch has a resistance of (9.9-9.4)/.4 = 1.25 ohms.
Perhaps that is giving the alpha 4 some problems. To charge it at 400 maH you have to supply .5 volts more than would be required in the absence of the fuse.
.... just a guess.
Perhaps someone can dig up the specs on the poly switch. That might help.
