RCU Forums - View Single Post - dumb question about the 2 tx knobs!
Old 11-02-2007 | 03:32 PM
selime's Avatar
selime
Default RE: dumb question about the 2 tx knobs!
ORIGINAL: FMB42
This link should have the entire HBK2 TX manual down at the bottom of the thread. You can also download this manual as well as an updated K2 manual from the Esky website ( www.twf-sz.com )
http://www.rcuniverse.com/forum/m_61...tm.htm#6183978
My K2 hovers at mid throttle with the left (HOV.PIT) knob set at the 2:00 position while a 12:00 setting on the right (PIT.TRIM) knob seems to give a reasonable headspeed and servo response. The setup on your K2 may require slightly different settings.
Good luck and good flying!
FMB42 Thanks for the setting on your TX. Interesting.. Being new at this I find if my left knob is at 9 or 10 position and my right knob around 12 I can hover somewhat..and have fairly decent tail control...but if I put the left knob at 12 I seem to get too much pitch and loose my tail authority. My belt is good and tight and the rotor box works really smoothly..ideas?...thanks
