this is the set-up i got,(thanks to james clegg,TopFuel4430),if this is what you have also,you can rotate the 3rd channel servo arm till it locks and manually adjust the needle to about 3 1/2 turns out,I noticed these cmb's like to run a fat needle setting,and as mentioned above,it will take some blipping to 1/2 throttle just to clear her out......but will be ok,once it hits the water....
