RCU Forums - View Single Post - Using two batteries at the same time - Update - Its bad!
Old 11-03-2007 | 09:17 AM
Kenny4842
Default RE: Using two batteries at the same time - Update - Its bad!
mrasmm, I bet you are right about the weight making the stock motor draw more amps. The thing is I had just got done reading on RCU about installing a fuse between the ESC and motor... I should have done it...it would have saved me in this case... You can bet I will be putting a fuse on the new one
