RE: dimentions of main spars
Thank you very much for your experience, is likely to do so with 2 to 1 / 4 x 1 / 2 balsa and sheet webs of 3 / 32 balsa and 2 aluminum tubes 1 / 2 from fuselage at the the third rib because the wings are detachable. an the gear landing set into wing.
