Thread: Sheeting Foam
Old 03-31-2003, 08:59 PM
DMyer
Default Sheeting Foam
You should leave it in the weighted shucks a long time if using any water based alphetic resin (yellow or white). The remaining water has been known to make the wood/wing warp in unpredictable ways if removed too soon prior to the wood/glue fully curing. I would leave it in at least 2-3 days if not longer. This is not a problem with either epoxy or the polyurethane Pro-bond. They both go off chemically and are fully cured in 24 hours. If it is not too late... I would suggest either Polyurethane Pro-bond or a good finish epoxy like Z-poxy or West Systems as a better alternative. Good luck.
dan
