RCU Forums - View Single Post - Need to set up a throttle/elevator mix on the 9Z
Old 11-09-2007, 07:06 PM
BrunoCH
Default RE: Need to set up a throttle/elevator mix on the 9Z
This is the way I do it on the Zap WC1:
After setting the mix, I program the throttle stick to be the on/off switch for mix. To do this, go to the Pmix screen and select SWT and STK. Select your throttle stick (usually J3), put the throttle where you want the mix to be activated and press SET. Make sure that, on the graph, ACTIVE is on the bottom of the travel, if not use the +/- key. It should work now.
