RE: Need help with diff fluids.
yes 2k will make a difference. but if you have everything too thick it won't turn for anything. lower the front to 3k and you will see a very big improvement. 10k in the center is pretty much the norm so your ok there.5k in the rear is ok but 7k in the front is way too thick. check around on different forums and see what the pro's are running.
