RE: sig 4* 40
My 4 * was squirrly on takeoffs too. Make sure the landing gear is mounted with the wheels as far back as possible. Also, if you can add a little toe-in it will help. Finally, I found that if I added a little resistance to the wheels, it also helped. I added a washer made from the fuzzy side of velcro for just a little resistance to the main wheels.
Scott
