RCU Forums - View Single Post - How do I adjust the shift points on my CT5?
Old 11-16-2007 | 06:08 PM
CEN Racing's Avatar
Default RE: How do I adjust the shift points on my CT5?
The shift adjust is located in the second gear shroud.... on the smaller of the two spur gears you will find a circular hole... rotate the cars wheels till you find the screw that appears to be at an angle... this is the screw you would need to adjust....
hope this info helps.. refer to step 5-5 on page 12 for a detailed graphic in your manual.
