Mono Turn Fins
Being new to mono's, I've never delt with rear mounted turn fins before. Can anyone help me mount the one that I bought?
Did I buy the proper side? (it's only sharpened on one side)
Is it best to mount the blade to the inside of the bracket or the outside?
How far over from centerline or how near the ouside of the transom should it be located?
Should it be mounted 90 degrees to the bottom surface where it locates?
It is going on a shallow V hull called a "Norco Eaglet".
