ORIGINAL: speed run
I have a Flash with a Ram 1000. The flight time is set for 8 min and land with a average throtle position balls out. I end up with about 3/4 '' fuel left in the main tank.The Flash is the only jet i have owned that has not been a BVM Jet. This plane is fast and the best pattern plane i've flown. Great job Comp Arf. I do wish the wing and door system copied the lighting.
Mike
Ditto!! - the GEAR DOORS!!!!
