RCU Forums - View Single Post - Hacker controllers
Old 04-05-2003 | 02:59 PM
BIGRCR
Default Hacker controllers
The Hacker Master 48 3P Opto would be one to use with the Logo 10. It works well and has a governor mode that works pretty good if you only use a single speed idle-up set up. It's set up is easy and straight forward and is completed with all stick commands. It does not like a two speed set up. Hacker should have their new version of the 48 3P Opto out by now.
Hope this helps!
