Hi Gerhard (sound German??)
No, I use the usual HD servo cables, but I keep them far away from the ECU and as far away from the turbine as possible.
For this purpose, I also made a 1/2 bypass (bottow only) from carbon fibre, so the cables are shielded from the turbin by
the carbon. I now have approx 40 flights on my F-16, and apart from one occurance of flutter on the rudder caused by a
faulty set screw, every flight so far has been perfect without as much as a glitch. This could also be tributed to my Weatronic
receiver and the dual receiver/dual antenna setup. It is still my all-time favorite jet!!
Tor
