RE: New Monokote Technique
Wow,thats awesome. Thanks lomcevek! Because I really enjoy covering,I'm sure I will no doubt be using this trick in the future.
I do have a question though regarding the use of trim solvent. You mentioned to go over the edges of the work at the end with trim solvent or just hit it with the iron to seal everything down properly. I've never used trim solvent,and wonder just what you mean by "go over the edges with trim solvent" Would you just carefully brush some on the the edges of the black decal and the solvent would soak into the adhesive under the decal itself and bond it? And does trim solvent only activate the adhesive and it wont disolve the covering?
So basically if I'm correct,trim solvent works the same way as windex only better maybe?
