RE: New Monokote Technique
Trim solvent is a HIGHLY agrresive version of windex. if you rub an almost invisible layer and stick some monokote to it it is there to stay. So the downside is that you only have one shot. Other down side is if you use too much then the colors will just wash away.
You did bring up a good point. I will make another vid describing how. But in short to answer your question you just run a moist Q-tip across the edge.
