Old 04-04-2003, 02:06 PM
ml3456
Default A couple of Smoke System install ??'s
If you use the HPD, putting it before the pump will give yout TME more battery life. If you put it after the pump and pinch the line, a lot of battery is wasted pumping against the restriction vs. a restriction drawing from the tank. Don't hard mount the TME, and wrap the feed line to the pump around the back of the tank and then up to the pump. This helps keep the line full to the pump during acrobatics.
ML
