RE: NEW INTEGY PARTS FOR BAJA 5B
Parts look nice. I have two questions.
1. Are there bearings, bushings, or nothing in the cross link?
2. Did they improve the angle of the steering linkage between the servo arm and the servo saver. Ideally the linkage should be parallel to the bottom of the chassis when the servo arm is in the neutral position.
Also, I have noticed that most of the steering slop in not necessarily form this assembly but from the plastic ball links. They tend to grow over time such that there is slop between the plastic ball link and the steel ball.
