RE: TF Cessna 182 Build Electric
I went ahead and ordered lights for the plane in the hopes of trying to make it as scale as I could. My first issue with them arose when building the Rudder. I opted to use a smaller tube to run through the assembly and can hopefully feed the wire through at a later time. If not, then once again I'll have to cut and re-sheet. After all, I'm getting better at it as time goes on. Check out the inside corner where I again forgot to install the torque block.
