ORIGINAL: timothy thompson
can you post i pic i have one and love it . You do know the prop is supposed to have a lot of downthrust. A pic and we can get ya flying again
The problem is I bent the prop shaft which is causing the gears to bind. If I can get the prop shaft off I can probably straghten it out. If not then I'll replace the gearbox (I ordered one anyway).
The bushing on the prop shaft doesn't want to come off too easily and there is no set screw. I'm not sure what it holding it on.
