Old 04-06-2003, 02:49 PM
DGrant
DGrant's Avatar
Default programming flaps on a 9C w/dual elev. servos
I have dual elevator servos in my Extra300, and they are programmed through channels 2 and 8 in the reciever, so that leaves wide open channels 1 and 6 for any flap/spoiler mixing I choose. However, even if you can program both flaps and spoilers for operation, I don't think you can have both active at the same time.
If memory serves me you have to activate one and inhibit the other, even though the settings shouldn't need to be touched once set, the operation will be in the activation settiing as far as which function you choose to use for any particular flight..... I hope I havent' thoroughly confused you, but this is how I do recall it. If anyone has more info, please chime in. Good luck.
