That location looks pretty good, I really didn't spend too much time investigating alternatives.
Am using the Robart gear, working very well so far. I think that maybe the Robart tees either have a little mold flash or are not completely round and that's what's causing the leak.
Craig.
ORIGINAL: tevans55
Craig-
It took a while but I found a spot for the switch and retract filler valve! I think H9 designed the front former on the belly pan so this stuff would fit. I used the plastic CJ tees in my Corsair and B-25 and have not had any leaks...may just be beginners luck. Hope mine performs as well as yours on its first flight. Are you using CJ retracts and what do you think?
Tim
