RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
Thanks. I looked again and everywhere else in the box and no luck. Also I can't get my servo extensions through the plastic tube with the heat shrink on my connections. The rudder extension came up about a foot short. The manual says to connect a 24 inch extension and the elevator has a 36 inch which works fine. I guess I will add a 12 inch extension to the rudder so it will reach. I will probably add a bigger tube since this one is to small.
