RCU Forums - View Single Post - Avistar four stroke
Old 12-09-2007 | 04:49 PM
TimC's Avatar
TimC
Default RE: Avistar four stroke
seemefly, the Avistar is smaller than most trainers. I have an O.S. .52 on mine and it has plenty of power. The Saito .72 would be overkill but would work fine. It is only a little heavier than most .46 two strokes, not almost double the weight. You should be able to balance the plane with a four stroke by moving the battery back.
