RE: Center of Gravity "CG" Computations
JRFisher - Ok, I understand what you are saying. Your calculator put you right on the spar when you selectd 10% as the point forward of the neutral point for good stability. The neutral point is as I would have suspected somewhere aft of the spar. Anything aft of the neutral pont would be considered tailheavy. Gotcha
