RCU Forums - View Single Post - Hangar 9 B-25 ARF: Building and Modifications
Old 12-10-2007, 01:10 PM
  #60
CRG
Default RE: Hangar 9 B-25 ARF: Building and Modifications
Pictures attached. Switches and valve are far enough outboard that they're out of danger in the event of a gear up landing.
Air valve and servo are mounted on a 1/8" lite ply plate that is glued to the fuselage side. The view in the picture is the l/h fuselage side, forward is to the left. Servo is a DS285 mounted in a plastic servo frame that is ca'd to the plate. The tray they're under is removable with four screws (comes that way in the kit).
Weight is 14lbs. 9ozs. Wing and fuselage weighed separately, it has a little fuel in it but not much.
Craig.
ID:	822802   Click image for larger version
ID:	822803   Click image for larger version
