RCU Forums - View Single Post - Revo w/ OS18TM wont start
Old 12-10-2007, 08:12 PM
ned289
Default RE: Revo w/ OS18TM wont start
ORIGINAL: FISH KILLA
Crank pin sheared or connecting rod broke??? Just guessing here of course.
I took the backplate off and the crank pin look very short as if its been sheared in half and not connecting with the starter shaft when i move the OWB. I also flipped the OWB around just in case it was backwards. When I move the OWB, the piston doesnt move unless I press the backplate really hard.
The Traxxas part number for the IPS crank shaft is 5219. Does anybody know if this will fit the OS18TM engine or should I find a specific part number for the OS engine itself? Also, is there just a pin by itself that I can buy instead of the entire crank shaft? Sorry for all the questions.
